add multiple folders with one drag and drop?
RichE
Is there a way to add multiple folders at the same time with Drag and Drop from Windows Explorer?
I tried highlighting/selecting several folders, then dragged but it only got one.
Thanks.
It's possible to drag and drop two folders at a time to set up a folder pair.
RichE
Thanks. I want to drag a whole bunch of folders to one side of the set. Then a whole bunch of matching folders to the other side. That would be a great feature, at least for me... :)
Guess I'll have to use the two at a time routine.
