Is SFTP supported under 32bit windows XP? The program installed and seems to run, but I'm missing the button for configuring the SFTP destination. Just to verify, I installed it in a windows 7 computer and I can properly use/config SFTP. Is there a workaround?
Henrique
windows XP and SFTP
The same here with Windows Server 2003. I can't configure SFTP. Why?
SFTP is implemented using a newer version of the Windows API that requires Vista or later.
