I have a NAS Unit with raid system using NTFS
i am attempting to setup up a remote filesync using SFTP
a ton of files get the following error
Error Code 123: The filename, directory name, or volume label syntax is incorrect
when i go to a (windows) computer with a mapped drive to the same folder i can right click and copy with no error.
the error only occurs during the batch sync
