FreeFileSync crashing during sync
Up until today FFS has worked perfectly, but now it's just closing itself in the middle of syncs (tested multiple times, always the same issue). There is no error message. One second it's open and in the process of syncing, the next second it's closed. Is there a crash report saved somewhere that I can view, to see what the cause is?
Same for me. Any way to get back FFS 8.8? I can't find the file.
Can you try the following version and see if the problem persists?
http://www.mediafire.com/file/t5b5h8ap9lrastb/FreeFileSync_8.9_Windows_Setup.exe
