Sorting by name seems strange in "Overview" with Chinese characters
nenotan
Hi~
As the title, when I sort the folders by name in the overview part, the ones in English characters are just ok, while those in Chinese characters have a strange order. The right order should be what in the explorer of Windows, but the order in the overview part is different.(I use the same ascending order.)
Please check if this is a bug or something with a certain reason.
Thanks!
OS, FFS version, screenshot?
nenotan
I created a folder with subfolders in Chinese characters to reproduce the problem.
FFS version is the latest 8.9.
OS in the screenshot is win10 64bit.(I also find the problem in other OS.)
You can see the order is different from that in the explorer while using the same ascending order.
Can you post the chinese folder names as text? Is this a regression compared to older FFS versions?
nenotan
二(er) 三(san) 四(si) 五(wu) 一(yi)
So e-sa-si-w-y(initial pin-ying letters), the order should be like that in the explorer.
You may reproduce it in the latest FFS 8.9.
nenotan
Thanks a lot for the quick response!
Wish FFS better and better.
