I'm very happy with freefilesync, but I miss one feature...I didn't find any information in this forum about tags in OSX. Is there a way to copy the tags of the files and folders?
I guess that on of these exclusion may cause the problem:
Maybe the spotlight-v100 one? But that's the default, so do I risk something if I delete this exclusion?
The target file system does not support HFS+'s extended attributes and FFS will not create AppleDouble files as fallback: viewtopic.php?t=2226
gigisteph
Ok! Thank you!
So I suppose the problem is that I have created the configuration for a HDD HFS+ to NAS, and then I did a "save as" of the configuration for the same HDD HFS+ to an external HDD HFS+...
But I guess I can remove these filters for both the NAS and the external HDD? As I'm using the files in the NAS via the MAC OSX finder?
The filters serve two purposes: 1. give a quick example of the syntax 2. exclude files that are generally not needed for backup, so feel free to remove them.
gigisteph
Hi!
I come back with the same question because I don't really understand:
Is there a way to keep osx tags when syncing from HFS+ to HFS+ ?
