Getting Started Problem
asker
I must be making the same mistake over and over. All I want to do is keep a few folders syncd. I am using two hard drives. I can't just point the right folder to an empty folder because the program says I can't. So I have tried copying the folders over to the hard drive. It seems that the program creates a Recycle Bin and puts a lot in there.
I have looked at the instructions but maybe I am missing something. What I do is drag the folders of the computer to the left side and it puts in the path. Then I (or already did spend a long time copying the folders in to the second drive) drag those into the right pane. all one by one into their own little box adding them with the + as needed.
Then I make sure it is set to Mirror and go.
What am I dong wrong?
Thank you.
