FFS and Android 6.0.1
sufferingbugs
I have been using FFS for the past few months syncing a PC W7 and a SD card on Galaxy Tab S Android 6.0.1 with Knox installed.
When it works it does it wonderfully but sometimes it does not. It compares files well but frequantly when syncing it hangs and no error message is displayed.
I found that selecting Permanent deletion of files and also unticking Delete moved files make syncing work again.
I have not stablish FFS as a definitive syncing sofware so far because it frequently hangs.
I like its interface and power and would be willing to pay definitely if it would work reliably.
I use the tablet as my portable PC for travelling with very most of capabilities I have on my office PC, but with better connectivity and portability. I suppose that every time most people will be travelling with tablets instead of laptops.
For that reason I would like to see improvements on FFS syncing Androids.
Thanks for your effort.
