I'm sure the answer will be no, but I'll ask anyway. :)
I am trying to find a solution that will allow me to archive/move files over a year old to the same folder path on a different server, so the production server only contains the files under a year old, and the archive files contains anything over a year old, preferably running weekly to move files from production to archive.
Is this something I'll be able to achieve with FFS? And if not, has any of you had to do something similar, and could suggest a solution?
File Archiving
