Deleting Dupes from only one drive
JessicaRN
Hey Folks,
So I need to do a massive delete and I'm naturally a bit concerned that I'll screw something up in the process. I'm hoping that one of you can point me to the proper configuration for the task I want to perform.
Ok, so my situation is this: I have two drives, F: & G:. They both have a directory tree called "\My Photos". I want to scan each of them and identify files that are identical in each directory tree and then delete ONLY the duplicates from the F: drive. This should leave me with a directory on F: that has only the files unique to that drive.
How can I safely and correctly use FFS to accomplish this task?
Thanks,
Jessica
