Before starting the batch, to avoid overwriting important data I would kindly know if the execution order of tasks saved in the file * .ffs_batch
It is from the top of the file to the down (end of file), or from the bottom to the top (beginning of the file).
This is because a first task saves certain files and folders from C to D and the next task saves the same files and the same folders from D to Z.
In the text file *.ffs_batch is essential to run before the task C > D and only after D > Z and not the opposite.
Work order file * .ffs_batch
