Wileyfox swift - CyanogenMod
Steph74
I use FFS to sync my phone (Wileyfox swift - CyanogenMod) to my PC and it use to work for both the following:
- 128Gb SD card to PC
- Internal Storage to PC
Internal Storage to PC no longer works and I get the following message:
Cannot find the following folders:
mtp:\Wileyfox Swift\Internal storage\BACKUP
If this error is ignored the folders will be considered empty. Missing folders are created automatically when needed.
Cannot read file attributes of "mtp:\Wileyfox Swift\Internal storage\BACKUP".
Cannot read directory "mtp:\Wileyfox Swift\Internal storage".
Error calling "IPortableDeviceProperties::GetValues".
HRESULT: 0x80042009, Facility: COM/OLE Interface Management
Any clue on what's gone wrong. I am running FFS version 9. I can see the phone storage from Windows 7 and copy/modify the files on the phone via Windows 7. I don't think I have change any permission on my phone but I might have done.
Thanks for your help
Should that not read "mtp:\\Wileyfox Swift\Internal storage"?
