CURLE_TOO_MANY_REDIRECTS: SSL_write() returned SYSCALL, errno = 10053 [curl_easy_perform]
Couldn't find much about this error, except mentioning of "general network instability".
10053 = WSAECONNABORTED
An established connection was aborted by the software in your host machine.
10054 = WSAECONNRESET
An existing connection was forcibly closed by the remote host.
alxvol
Yes, I think that the problem is in hosting, but I can't change it. That's why I think that the number of retry attempts option would solve my problem. Or if I had the ability to rescan only elements with an error.
In the options I found "Automatic retry on error" section, but I don't understand when these options are used. I set Retry count and Delay, but it doesn't help.
914tom
Hello, since upgrading to 9.7 I have the same problem:
CURLE_OPERATION_TIMEOUT: FTP response timeout
I never had this problem with older versions and as the machines are on the same LAN I do not think that there should be major latency issues!
Are there any changes on this FTP code between 9.6 & 9.7?
alxvol
I checked one of my old sites with 9.7 version and have the same errors.
For another site, I solved my problem by changing ftp server from original Windows to FileZilla.
Maybe the problem is not quite the same, but I still think it would be useful if I could turn on something like an auto retry mode or set timeout of transfer operation, because when I click retry button the same files processed successfully and scanning continue.
This is not so convenient if you have 1000 files and 100 of them break with the error.
This could be a simple and quick solution, I think.
