Anyway to disable sync.ffs_lock file creation?
webmastir
I was wondering if there's a way to turn off sync.ffs_lock file creation during a one time sync process?
And/or a way to specify where the sync.ffs_lock file is created? I have a sync process syncing a folder that is watched by a File Watcher of some sort. It thinks sync.ffs_lock is something it's supposed to consume (no way to filter that either).
webmastir
Nothing eh?
See help file chapter "Expert Settings" on how to disable the lock file.
webmastir
Wow I'm an idiot and completely missed those obvious settings.
Thank you Zenju.
jackdashack
I am not seeing a Global Settings in my FreeFileSync folder. And by reading the expert settings it's not clear to me but I'm not an expert? I delete the lock file and it comes right back. This started out of the clear blue when it had been running well all along?
Make sure FFS is completely closed before editing the settings file, otherwise the changes won't stay.
jackdashack
xCSxXenon: extreme ignorance here. Covid has eaten my brain. :-\\ How do you edit the settings of a program if it is closed before you edit it? Is it a separate file in the program folder? I checked. And if I try to edit the _batch file it opens FFS. Thanks for putting in here for us!
jackdashack
Should it look like this when I'm done to disable lock files. I am obviously not as geeky as I'd like to be or are you all are. This is what I've done . . . . of course it can be undone.
<FileTimeTolerance Seconds="2"/>
<RunWithBackgroundPriority Enabled="true"/>
<LockDirectoriesDuringSync Enabled="false"/>
<VerifyCopiedFiles Enabled="false"/>
jackdashack
I changed a bad line in the above.
I'm assuming that's not the whole file and is just a snippet containing the important code.
That looks correct, is it not working as expected?
jackdashack
Yes, just a snip. It's running, I guess it's stopping the lock files. But I haven't stopped if from running. I am going to the next answer which is about the multiple listings in Task Manager and see what you are recommending there. ty so kind for your help to this point! ":-Dx
jackdashack
I changed <ProgressDialog Minimized="false" AutoClose="true"/>
