Yes I've been having problems with FreeFileSync with Sandisk 128GB Flash Drive; when trying to synronizing them; the ones that are being syncronizhed to the original isn't the exact size as the orginal; it usually is much much bigger let's say the orginal flash drive is 95GB; the clone would be 110GB.
Secondly I'm an idiot I've never been able to understand FreeFileSync's best feature 'RealTimeSync'; so over time I would try to sync my other flash drives but to no avail; then finaly I believe it may have been FreeFileSync “an accident” that locked my most important drive; it took me 2 ½ weeks to recover the data I could go on; but if someone could explain in detail the easy way to use FreeFileSync, and then utilize RealTimeSync.
I suffer from Bipolar Disorder and Schizophrenia w/ADD and slight Cerable Palsey so certain concepts or sometime the most simplest tasks provide the hardest road traveled. I have 100% confidence in FreeFileSync is the absolute best program for the job, I just need a little guidance.
Please Help
mebtech81@gmail.com
Unknown Problem while trying to Sync Files; and FreeFileSync is possible locking the drive so Windows cannot gain access to it.
