RealTimeSync does not sync
Array
I created a batch file for real time sync. It is supposed to sync my home directory (Ubuntu) to an external HDD. When I open the batch with FreeFileSync it works perfectly. However, once let it run with RealTimSync it doesn't do anything, even though I change folders and files. The system status says the program is active every 10s (which it should).
Any ideas what is going on?
Array
