Hello folks,
I do a file-backup from a Windows 7 pro SP1 maschine to a SMB network share on a Apple maschine (MAC server). In the past it works fine, but since I updated FreeFileSync to Version 9.2 the last days, some errors occur:
Warning The directory lock for "M: \ WINWORK" can not be set.
and then:
The file "M: \ WINWORK \ Del.sync.ffs_lock" can not be written.
Error code 64: The specified network name is no longer available. [Write File]
In the Windows Explorer I can access the share, can write on it - no problem. But FreeFileSync won´t work?
Does someone have any suggestions for that problem?
Thanks a lot!
Joe
Error Code 64
Did you ever figure out the solution for the error code 64 problem? I'm having the same issue. Thanks.
