Version 9.2 does not work on Ubuntu 16.04 32 bits
upboetendael
Up to version 9.1, I could update FFS on my Lubuntu 16.04 32 bits system using the Debian 32 bits tar.gz file offered in the download section.
But with 9.2 this doesn't work anymore. The executable files contained the tar.gz archive do simply not start, nothing happens when trying to execute them.
Has this something to do with the new Debian 9.0 base used for the compilation ? Previous 9.1 was based on Debian 8.8
Many thanks beforehand for your help
frvm
same problem on ubuntu 16.04 32 bits ! No possibility to start it. Is there any solution please ?
Thank you very much.
