Is there a way, in the mirror mode, to know the size of the files about to be deleted?
For instance, if I remove a 30 MB file in the source folder and launch a comparison, in the stats on the bottom-right corner, it will just tell me one file will be deleted in the destination folder. The stats' window will still display "0 byte". I think it would be interesting that it would notify "- 30 MB" instead.
Is there a way to do that?
Amount of deleted files
