RTS does not start
rainman1962
I have created a FFS batch file. I then copied the batch file path to RTS command line. The command line reads as follows: "/Applications/FreeFileSync.app/Contents/MacOS/FreeFileSync" "/Users/Jeffrey/Documents
/FreeFileSyncBatch.ffs_batch"
If I leave the idle time as it defaults at 10 seconds, FFS will run every 10 seconds, even if I don't change any files. However, if I change the idle to 100 or 1000 FFS will never run, even if a file is changed.
FFS is set to update. The batch file runs fine when selected manually with no problems.
Also, I have to click on FFS twice to run the app. Is this normal behavior?
Thanks in advance!
