Windows: Locked files (outlook) not copied
petur
After a sync there's an error box telling me some files were not synced, and those are outlook files. There is no other error coming up.
Verified that volume shadow service is running
FFS is started as admin
Windows 10 (sadly)
When outlook doesn't run the copy works. But this setup will get automated so it will need to deal with this in the end.
Any hints on how to debug this issue?
thanks!
petur
Yes, and I think it doesn't apply to Win10, as stated in the KB:
Note This article is not for use with Windows Vista, with Windows Server 2008, or with later operating systems. Starting with Windows Vista and with Windows Server 2008, Windows component installation is manifest based. If you try to manually register specific components, such as those that are described in this "Resolution" section, in the operating systems that are mentioned in this note, unexpected results may occur that may require reinstalling Windows to resolve.
Gianni1962
Sorry, I mean only the first part where states you need to configure FFS and run it as Administrator.
petur
yes, FFS is configured correctly in the options, and started as admin (using right-click, and the windows security question comes up as expected)
Gianni1962
Ops, seems I should sleep more, you stated this already in your first post ... sorry!
Gianni1962
Mine environment is like yours.
I'm using the latest FFS version 9.2.
The Sync of a locked file goes well thanks to the creation on the fly of a volume shadow copy of the E: drive.
FFS is notifying me of that in the Sync status window.
When I try to Sync with the option to "Copy locked files" unchecked, a popup window correctly informs me as follow:
Cannot read file "E:\TEMP\Test\Dummy 06.DBF".
The file is locked by another process:
Microsoft Visual FoxPro 9.0 SP2, "E:\Programmi\Microsoft Visual FoxPro 9\vfp9.exe"
Take a look at the Windows "Event Viewer" to understand what's going on, some hints at this link:
Troubleshooting Volume Shadow Copy Errors: First Steps
http://backupchain.com/en/troubleshooting-volume-shadow-copy-errors-first-steps/
petur
I didn't see any of those things mentioned so that's already something to check.
Thanks for that link, too
My timing for posting the question was a bit stupid as I'm off for a short break. I'll report back when I can have another go at this!
Thanks for your input
Gianni1962
Make sure you have Handle errors -> Pop-up in Synchronization Settings (F8).
petur
oh, I may have had that one off so that would explain something already. Thanks!
Giangi
When outlook doesn't run the copy works. But this setup will get automated so it will need to deal with this in the end.petur, 17 Jul 2017, 16:58
If the files in use (you didn't specified extensions) are .ost then these are by default excluded from shadowcopies or any backup/copy made via VSS.
https://msdn.microsoft.com/en-us/library/windows/desktop/bb891959(v=vs.85).aspx#filesnottosnapshot
Personally I do not use FFS as a backup solution, but I had to modify the above key removing "OutlookOST" to have them included into both the "Previous Versions" and into the backup.
BTW: instead of deleting it I suggest to just remove the two "dollars" from the $UserProfile$ key so to not match anything and to be able to restore it quickly!
If the files in use (you didn't specified extensions) are .ost then these are by default excluded from shadowcopies or any backup/copy made via VSS. Giangi, 18 Jul 2017, 12:36
That caveat does not apply to FreeFileSync, which includes "ost" files as well:
viewtopic.php?t=1387
Giangi
...but the registry change i still worth trying... (IF the file in error is an .OST one)
...but the registry change i still worth trying... (IF the file in error is an .OST one) Giangi, 18 Jul 2017, 19:44
Until the OP posts an actual error message, it's all guesswork as to what has really happened.
petur
Finally had time to investigate again...
The error that FFS gives is (sorry, the system runs Dutch version):
fout: Kan het bestand "C:\Users\Joris\AppData\Local\Microsoft\Outlook\Outlook.pst" niet lezen.
Foutcode 33: Het proces heeft geen toegang tot het bestand omdat een gedeelte van het bestand door een ander proces is vergrendeld. [ReadFile]
There are no VSS errors in the windows logs. When I stop VSS and start it again there is an entry so I look at the right logs I think. Tried vssdiag from backupchain, it says no errors found.
There is no registry key to exclude files
I checked VSS storage even cleared it:
PS C:\WINDOWS\system32> vssadmin resize shadowstorage /for=C: /on=c: /maxsize=1GB
vssadmin 1.1 - Volume Shadow Copy Service administrative command-line tool
(C) Copyright 2001-2013 Microsoft Corp.
PS C:WINDOWSsystem32> vssadmin resize shadowstorage /for=C: /on=c: /maxsize=50GB
Successfully resized the shadow copy storage association
PS C:\WINDOWS\system32> vssadmin list shadowstorage
Shadow Copy Storage association
   For volume: (C:)\\?\Volume{e3231c8a-8346-11e1-a178-806e6f6e6963}\
   Shadow Copy Storage volume: (C:)\\?\Volume{e3231c8a-8346-11e1-a178-806e6f6e6963}\
   Used Shadow Copy Storage space: 0 bytes (0%)
   Allocated Shadow Copy Storage space: 0 bytes (0%)
   Maximum Shadow Copy Storage space: 50,0 GB (10%)
I get the exact same error if I let FFS use VSS or not, I see no different behaviour at all. And I am 200% sure it runs as admin. I have zero indication that FFS is actually trying to use VSS.
I feel I reached a dead end... suggestions welcome
petur
@Zenju (I saw your short reply) is there a way to debug if FFS is trying to use VSS or not?
I've fixed the issue which was related to locked byte ranges not being considered by FFS, but now they are:
http://www.mediafire.com/file/pov3c9iceib39pm/FreeFileSync_9.4_beta_Windows_Setup.exe
petur
wow, great.
Will try this as soon as I can.
thanks!
petur
SPAM...
but it reminded me I never got back here to report that it effectively fixed the issue I saw, the system is running sync fine now
