i have a SD memory of witch i write a lot of data (files and folder) using Freefilesync. At the moment the files are there, i can read and copy them but i am no more able to delete the file or format the moemory. I saw a file called Synk.ffs_lock. I read that this file is created from Freefilesync. I suppose something went wrong and that file lock all the momory. I can't delete it, i can't nothing. any help?
synk.ffs_lock
Restart your pc and then you should be able to delete the file.
Thanks. It doesn't sort any effect.
Very strange,
Restarting the pc close for sure any open file and, if you don't retry the same operation with FFS, the file Synk.ffs_lock should be freely erasable.
If not, I would suspect a problem with the memory card.
Try the delete or the format on another pc.
Thank again.
Any file i delete, it appears again. When i run Freefilesyng i get the message a process is already running (but of course it is not). I used also a different PC, also a Mac. Nothing to do.
The SD memory card is probably near its end of life.
https://www.sdcard.org/consumers/faq/#servicelife
They speak about 10 years but in my personal experience it is too optimistic.
Mine 32 GB Samsung SD used in my Galaxy died after 4 years.
Friends SD lasted less.
They are not reliable as a daily backup support.
If you rewrite it every day expect their life to be even shorter.
