I've been using FreeFileSync for a while and never had a problem until version 7. I use it at my laptop with windows 7 and on my MacBook(Yosemite) to sync files. I always try to keep the same version on both machines.
Since version 7 every time I sync the files on my Mac got the following error:
Cannot write file "/Volumes/XXX/SyncGrupoSecurity/.sync.tmp.ffs_db".
Error Code 45: Operation not supported (fcntl, F_PREALLOCATE)
Hit Ignore and get the error log.
The files are being synced.
The problem is not present when I use the Windows version.
Can anyone tell me why is happening this error on my Mac Book?
Thanks!!!!!!!!!
Sergio
Error Code 45
This is fixed and I've already updated the 7.0 version in order to not have to wait until the next release.
Problem solved!!! Thanks
