I'm pretty sure that this is a newbie mistake, but I've conducted many tests to get a better understanding and I'm just not getting it.
First :
Version : 9.2
OS1 : Windows 10
OS2 : OS X Yosemite
From Windows I'm trying to a sync a Shared Folder (actually and entire drive) on my OS X machine. In Windows that OS X folder is called "Z:". The target is a USB drive connected to my Windows machine. That drive is "D:". See image1.jpg for how this appears in FFS.
When I try to Compare, I get and error that states, among other things, "Cannot find the following folders". See image2.jpg attached.
When I click to ignore errors and all subsequent errors. The Compare works as I would expect. Then when I go to Sync (Mirror) I get a Source Folder Not Found error box. You can see this in image3.jpg. Note I know that the "Y:" in image3.jpg does not match the info in image1.jpg. That pic is from a test I did. I'm wary about somehow nuking my source data...so I, as I said, setup a number of tests. I haven't gone this far against my real data.
Anyway, I'm confused.
Thanks for your time!!
And Thanks to the developers for a Kickass program. I've been using it for about 6 months now and am very impressed...especially the speed!!
Cannot find the following folders...
I don't see my attachments in this message???
One other thing I should add is that the target drive D: is empty. There is no folder structure of any kind there.
In general image attachments should work fine on this forum.
