I have the latest version 9.3 installed. System OS is Windows 7. I am getting the following error. Please resolve.
_____________________________________________________________
|08/18/17 - BatchRun: Synchronization completed with warnings
| Items processed: 1 (92.6 KB)
| Total time: 00:00:02
[10:12:34] Warning: The following items have unresolved conflicts and will not be synchronized:
"_gsdata_\_file_state_v4._gs": Both sides have changed since last synchronization.
[10:12:34] Info: Synchronizing folder pair: [<– Two way –>]
D:\RSM
Z:\RSM
[10:12:34] Info: Updating file "D:\RSM\STATUS OF PENDING ISSUES.pptx"
[10:12:34] Warning: Synchronization completed with warnings
Items have unresolved conflicts
Why would FFS need to resolve something here?... Please resolve.b2man63, 18 Aug 2017, 04:51
FFS does what it is supposed to do: it signals a (potential) conflict, as the mentioned file has changed on both sides (left and right) since the last FFS sync was run, so it is not clear to copy over from where to where (if at all).
It seems you are running GoodSync next to FFS.
I don't know GoodSync in detail, but it seems "_file_state_v4._gs" is a GoodSync specific file, comparable to a "sync.ffs_db"-file as used by FFS.
In that case, it is likely not desirable to sync the "_file_state_v4._gs"-file at all.
The simplest thing to do in FFS is then to exclude the "_file_state_v4._gs"-file (or the entire "_gsdata_" folder) via the FFS exclude filter.
Issue resolved. Thank you.
