Mirror entire drive contents??
jctarvin
If I want to set up a drive sync (including all folders and files) can I set source as G:\*.* and target as H\*.*?
If that won't work, is there another way to do this?
Many thanks!
If you want to sync all of drive G: to the root of drive H:
* define G:\ as your left location and H:\ as your right location
* your include filter should contain just the default * (meaning: everything included)
* your exclude filter should be empty (meaning: nothing excluded), or just contain the default exclusions (meaning: exclude the recycle-bin and for backup non-relevant files)
