First off, I am not an experienced user of this app (but a Windows user since 1993).
I installed the new version, opened it and immediately got the error message I've posted below. Took a screenshot and moved on.
But it failed to load the folder list for that configuration file also, and upon leaving it to click on another in my list (see 'My List' screenshot) it asked me if I wanted to save the changes (which I hadn't made, but the program did). I first answered No, then later Yes, but either way I can't get a list of folders to appear.
It's doing this with every configuration file in my list. I have said "Yes" to the Save dialog on two of them, have said "No" on some others, but all refuse to show my lists of folders/files that were saved in the 'ffs_gui' prior to the upgrade.
I suspect that it broke things enough that I'm going to have to build those configuration 'ffs_giu' files all from scratch, but I'm writing you folks just in case.
Thank you,
Mike
Upgraded from 5.2 to 9.3 and it broke things.
