RealtimeSync is waking up Windows 8.1
schildkroetewd
Hi
Every time I have got RealtimeSync running, it keeps waking up my Windows when it falls asleep. I didn’t notice this behavior before version 7.0 of FreeFileSync. The thing is, once I close the notebook lid to stove it into my bag, when I take it out of it is running again.
When I query my Windows for the reason it woke, I receive the following output:
C:\Windows\system32>powercfg /lastwake
Wake History Count - 1
Wake History [0]
Wake Source Count - 1
Wake Source [0]
Type: Wake Timer
Owner: [PROCESS] \Device\HarddiskVolume4\Program Files\FreeFileSync\Bin\RealtimeSync_x64.exe
Owner Supplied Reason: generic
C:\Windows\system32>powercfg /waketimers
Timer set by [SERVICE] \Device\HarddiskVolume4\Windows\System32\svchost.exe (Sys
temEventsBroker) expires at 23:22:04 on 26.05.2015.
Reason: Windows will execute 'NT TASK\Microsoft\Windows\TaskScheduler\Regular Maintenance' scheduled task that requested waking the computer.
Timer set by [PROCESS] \Device\HarddiskVolume4\Program Files\FreeFileSync\Bin\RealtimeSync_x64.exe expires at 19:22:39 on 26.05.2015.
Reason: generic
Reason: generic
Is this behavior really intended? If it is, would it be possible to have a configuration item to disable it?
Thank you for your support.
Cheers
Daniel
wm-sf
Hi
Wake History [0]
Wake Source [0]
Type: Wake Timer
Reason: generic
Reason: generic
Cheers
Danielschildkroetewd
Isn't FFS simply doing what you asked it to do and if you want something else you should say so ?
There is no change between FFS 7.0 and earlier versions that could explain such a behavior and FFS does not set any wake timers. If you have steps how to reproduce this behavior, I can try to find out what is going on.
chmark
There is no change between FFS 7.0 and earlier versions that could explain such a behavior and FFS does not set any wake timers. If you have steps how to reproduce this behavior, I can try to find out what is going on.Zenju
I second Rotus Natter's problem. Same behavior on a Win7 64-bit machine, same info from powercfg. Really annoying, otherwise a superb software!
More info:
ffs_batch file attached. Both source and target are on encrypted drives (Diskcryptor) if that can be significant.
schildkroetewd
Thank you for your response. I attached 3 files I am using FFS with.
I did not notice this behavior before version 7.0 but i am pretty sure I left out version 6.15, so I cannot tell you whether this behavior has been introduced with 7 or before.
I am using FFS to synchronize a local with bitlocker encrypted drive and a CIFS Network share.
wm-sf
encrypted drives is the obvious common denominator
chmark
encrypted drives is the obvious common denominatorwm-sf
and of course FFS... :)
and of course FFS... :)chmark
novice users? SCNR :)
boost is using "CreateWaitableTimer". I bet this is caused by a boost bug or even worse, "feature". Continuing investigation...
I am not able to reproduce the problem on my Windows 7 system, but it is reproducible in your test cases, right? In this case I could create a test version with a patched boost build and see if this solves the wake up problem.
chmark
It's easy enough to test if You make a patched version. Let me know when and where.
(and Yes, I'm a novice FFS user...)
Here's the new version with patched boost, which should not set wake timers anymore:
[404, Invalid URL: https://freefilesync.org/FreeFileSync_7.1_beta_Windows_Setup.exe]
chmark
My problem seems to be fixed. Win7 64 PC is sleeping in peace, no timers active anymore:
C:\>powercfg /waketimers
There are no active wake timers in the system.
Thanks Zenju!
schildkroetewd
[404, Invalid URL: https://freefilesync.org/FreeFileSync_7.1_beta_Windows_Setup.exe]Zenju
Hi Zenju
I can tell you too, that there are no more wake timers when running RealTimeSync. So thank you very much for this quick fix.
