v7.0 on Mac OS X not launching
ptoche
Hi Zenju,
The latest version 7.0 does not launch on my Mac OS X (Yosemite 10.10.3). I downloaded it several times to make sure. I have reverted to 6.15, which is working well.
What do you mean with not launching? Do you see an error message?
PS what is the modification date of the FreeFileSync executable contained in the app bundle?
ptoche
No error message. Nothing at all happens. Clicking on the icon is like not clicking on it. Not sure about the modification date: in the Finder, under "Date Modified", it has today 01:37, which is 1 minute ago when I unzipped it to check the modification date. I don't think this is the date you want.
djronh1
I couldn't run either initially.
Problem was the executable (within package) was only rw, missing x bit.
do a chmod +x FreeFileSync.app/Contents/MacOS/FreeFileSync
Where is this permissions problem coming from? I just tested downloading and running with OS X 10.10, but executable bits were set (albeit only for user).
It seems zip can indeed store permissions, at least on OS X: I've updated the application bundle to use 0755 and uploaded the new 7.0 release file for OS X.
ptoche
Wonderful, thanks!
