Not operate automatically
dream4fly
I prepared three stage backup process.
The first is to monitor 3 specific folders. If RealTimeSync catch some changes in these 3 folders, it excute pre_ designed stage_o batch file. The batch file mirrors the 3 folders to another hard disk.
The second backup process is done by task scheduler every hour. It mirrors from backed up data on hard disk to USB1.
The third backup process is done by task scheduler every hour too. It mirrors from USB1 to USB2 after 15 minutes the second backup process is done.
These are worked very good. But some days ago, problems are found. These processes are not work automatically.
All the process is wait for my action. RealTimeSync catch some changes in the specific folders, it open FreeFlieSync program and wait my action F9. Other two other batch files which worked by task scheduler are same.
I tried many changes. But the result is always same. My OS version is Windows 10 RS3 Build 16299.
I hope to go back previous heaven.
