Schedule problem - FFS wont do anything
Jukkiss
I have tried couple of times to make FFS to run on schedule. I haven't been able to do that correctly.
I have Windows Server 2012 R2, and I have scheduled one specific batch job. Driving that batch job manually, it works without problems. But when put under a task, it wont do anything. Windows task scheduler shows, that the task has been running okay but nothing is synced. Task settings include "run whether the user is logged or not". Before the batch job task I must run one specific action, I do believe I did that correctly?
Via link you can see the task actions:
https://imgur.com/3MXQBtH
What could be done?
Best regs
Nico, Finland
Gianni1962
Did you follow the instructions in the manual?
https://freefilesync.org/manual.php?topic=schedule-a-batch-job
Jukkiss
Hi Gianni1962,
Yes, I absolutely followed the instructions. I did my very best to do exactly as said in the instructions.
Nico
Gianni1962
Please attach your sync job so we can look at it!
