2TB 1,000,000 file graph on progress dialog
dliversi
It looks like there is a counter limit on the Progress Dialog seem to be limited to 2.00 TB and 1,000,000 files copied.
The graphs just flat-line at that point and don't increase and the bytes/sec and items/sec stay at 0. The summary Time Remaining also give up, but the summary Items Remaining and Time elapsed values still look to continue as normal.
dliversi
I've just been looking more at the sync I'm doing and it looks like the sync has broken, so the flatline might just be the files not copying..
The copy looked to still be processing, but it had already taken 30+ hours, so I stopped it to copy them manually through explorer, but when I looked at the state of the target directoies it looks like files it was processing before I stopped it are all tmp files. Every file that it was created has created 11 empty files named _0.ffs_tmp to _9.ffs_tmp and just .ffs_tmp. The log also shows a copy error on the _9.ffs_tmp version.
18:25:34 Error Cannot copy file
"Z:\J\Windows\CSC\v2.0.6\namespace\liberator\dliversi$\.bashrc" to
"\\TerraNAS24\dliversi\Data\Z\J\Windows\CSC\v2.0.6\namespace\liberator\dliversi$\.bashrc_9.ffs_tmp".
Error Code 80: The file exists. (CopyFileEx)
