Realtimesync: MTP Protocol does not support directory monitoring on Android
username331
Hello. I have a Samsung J7 Prime running Marshmallow. I tried to synchronize one folder of the phone with another folder on my PC using FreeFileSync and it worked fine. Now, I wanted to make the synchronization automatic everytime when I insert the phone to my computer.
1- I saved a batch file of the configuration I used in the mirror syncronization in FFS
2- I opened realtimesync and drag-and-dropped the batch file. Now I wanted that the two folders be in sync automatically.
3- Clicked on "Start"
RESULT: Error: MTP Protocol does not support directory monitoring:
"mtp:\Galaxy J7 Prime\Phone\DCIM"
Does anybody have a solution for this?
