.ffs_db files are differently named wiith Linux and Windows clients
Hythloday
I have a file server that I keep updated from a Linux and a Windows client. Unfortunately, the Windows client generated a "sync.ffs_db" file whereas the Linux client has ".sync.ffs_db" which means that Two-Way synchronization isn't moving files as it should be.
Is there a way to rename the .ffs_db files that a client creates?
The two database file formats should only ever be a problem if you sync the same folder pair, sometimes from Windows and other times from Linux. Is this what you're doing?
Hythloday
Not the same pair, two pairs with one shared element. Like:
Folder (Windows) <-> Folder (Server) <-> Folder (Linux)
Changes that occur between Windows/Server aren't reflected in ".sync.ffs_db" - moving any files around on the Windows side and having it sync up with the Server means that when I do Server/Linux, it doesn't know that I moved things and instead tries to copy things.
This isn't a problem of the two database formats. More likely the server doesn't support file ids when scanned from the Linux side.
Hythloday
Oh, interesting. Where can I learn more about how those work? The server itself is FreeNAS and it's working through a SMB share - possibly I'd need to access the server through an NFS share instead?
Hythloday
Update: Switching to SFTP instead of SMB made it work properly. For reference: Linux and Samba do not play nicely with file ids as far as I can tell.
