FTP needs auto Retry
RodG
Hello, my first time posting here so if I am missing some sort of protocol for posting I apologize.
I receive an error most of the time I attempt to synchronize to an FTP.
This is usually the first error I receive:
Cannot open directory "ftp://--omitted--".
CURLE_OPERATION_TIMEDOUT: 421 Could not create socket. [curl_easy_perform]
If I press retry a couple of times through various possible progressive errors, it works fine. I searched the forum and found this was previously discussed, but that was a long time ago.
viewtopic.php?t=4485
I am using ver 9.5.
Seems to me if the 'Retry' and 'Delay' parameters from Tools Options applied here as well all would be fine.
Is this actually implemented and I don't know how to turn it on?
Excellent App
Rod Gallagher
Auto-retry is used for FFS batch jobs and the synchronization part of GUI syncs, but currently not for the comparison phase. The reasoning is that the most-likely error is a folder that cannot be found in which case a retry would be useless.
