I tried to exclude a folder named #recycle (from a Synology NAS), but failed to do so. Options I have tried:
\#recycle\
*\#recycle\
\\#recycle\
\[#]recycle\
I couldn't find anything related to that in the doc, might be that # is some kind of special char for FreeFileSync?
cheers,
Martin
HowTo exclude #recycle ?
thanks for sending me that link, I already checked that prior to posting here. Even after reading it again I don't understand why excluding
\#recycle\
doesn't work.
\#recycle\
doesn't work.
Try to exclude it from the FFS GUI via the right-click context menu.
Thanks, that did the trick. No idea why as it adds the same text to the exclusion filter:
*\#recycle\
Anyway, thanks a lot!
*\#recycle\
