Hi there,
as mentioned in the subject, what is the difference between the 2 in Run command after sync?
My goal would be to execute a script only if a file has been transferred from one side to another ("Update").
Thanks,
schiggi
In Sync Tab, difference between "On completion" and "On Success"?
"On completion" covers both "On Success" and "On Errors". Do you have a better term?
Ah, ok, thanks. Unfortunately, don't have ideas for a better word. Maybe just simply: "On success and On error"?
But coming back to the functionality, on success means the success of the batch (without errors), not necessarily, if there has been a file transferred or not?
My goal would be to transfer/update a file to my server if file has been updated by 3rd party program. If transferred, then execute a script via SSH. Any ideas, how to execute a command only if a file has been transferred?
