I wanted to use the Tool "Export file list..." but don't see how.
I tried exporting with only one session and then by selecting a number. I get a file that opens in Excel, but it essentially empty. Shows only:
"Folder Pairs
Relative path Size Category (F10) Action (F10) Relative path Size"
and not other information.
Please tell me if there is a Help section on using this command, or how I may be using it wrong.
I want to be able to save and use on a rebuilding of my Windows, the list of commands.
Thank you, Walter Teague
how to export file list and use results.
The generated CSV file contains the folder pairs and eventually the files shown but you must at least have done a compare.
