Problem when uploading certain files at macos
SipriusPT
I had a problem where if I simply copy and paste from a local folder to a remote folder it paste it right, but if FreeFileSync do it, my file changes from Document to Unix executable, and I really dont know why. I have already check extended attributes and all seems fine from terminal.
Here are some prints that I have take:
Download: Image
Upload (remote and local folders are in the same order as the above print): Image
Here is a link to my files: https://www.dropbox.com/s/phw9l8q0xlbahrj/Componentes_ext_attr_mac_filetype.zip?dl=0
This problem occours at least with FFS 9 and 9.5.
Help!
Seems like the execute bit is being set somehow. What do you get with
ls -l
for source and target folders?
