I'm currently using FFS to synchronize about 11 GB of data between two servers that are connected via a 8 mbit/s VPN connection. After the first full sync which took around 4 hours overnight, now the typical amount of data is about 100-200 MB per day.
Are there any plans to add a feature to limit bandwidth because I would like to keep enough bandwidth for VOIP-Connections and normal file sharing which is running over the VPN as well?
Thomas
Limit bandwidth consumption, throttling
Any decent modern router has QOS, and will prioritize real-time application traffic
(VOIP and some multimedia) over file transfer or web browsing, either by default
or otherwise after proper configuration.
At least as long as the VOIP does not originate from the same computer as the one
running FFS (like when using a VOIP telephone), that should already resolve the issue.
