First of all thanks for your great software!
I realized only a few minutes ago of a problem with RealTimeSync.
I'm using Realtimesync to trigger a freefilesync batch file. This file syncronizes a source folder C:\USERS\username with its target T:\username, where T is a network drive.
Synchronization setting is "Two ways".
All goes well when I add, delete, rename, move a file inside the folder "username" in C, and also in its subfolders. The changes propagate well in T\username folder and subfolders.
All works also when I add, delete, rename, move a file inside the folder "username" in T (propagating to C), but not if I change something in T\username\subfolders. These changes are not detected by Realtimesync, so FreefileSync is not started and synchronization does not occur.
Can you please help me?
I'm using version 7.1 because with version 7.2 an error of translation occurs...
Thank you so much
RealTimeSync does not detect changes in target subfolders
Detection of changed files is fully supported for local file systems (since Windows XP). For network shares it may or may not work, especially if client or server OS are older than Windows 8.
PS: the translation error should be fixed if you re-download the latest release.
