GetFileAttributes: Code error 3
jval
Problem attributes on my backup copy.
Here is my environment:
80 workstations in Windows 7 in a 2008R2 domain. I just installed a dozen posts in Windows 10 pro. I use FileSyncFree 9.5 to make a GPO backup at user logoff between the "My Documents" folder and a user network drive.
So far on Windows 7, everything works but with windows 10 I have this error message: error code 3
Here is the complete message (in French)in attachment.
Can you help me ?
Thank you
Jérôme
Note that drive mappings (e.g. your U:-drive) are user specific.
Make sure that your scheduled task is run under user credentials for which a U-drive is defined
and mapped to the intended location. And has suitable read and/or write rights there.
Conversely, instead of using drive-letter mappings you can refer to the network address
(e.g. \\[IP-address]\[ShareName] ). This is user independent.
Obviously, the user under which the scheduled task is run still needs to have
suitable read and/or write rights in the respective locations.
jval
Thank you but the rights are well defined for the user. The rights and the mapping are the same way as on my posts in windows 7.
Can be a problem of law on windows 10?
