show changed files on top
Is it possible for the program show changed files on top after it does a "Compare"?
Can you explain how that would differ from what FFS shows now? From my perspective, FFS only detects changed files. What it "shows" are the files it believes are changed and should be mirrored/synched (whatever your actions are specified to be). It seems to list them alphabetically.
