Error Code 4390: The file or directory is not a reparse point. (CreateSymbolicLinkW)
kadsf
I am using seagate central personal cloud to back up my USB drive on a windows 8.1 PC.
USB drive letter is X:.
Seagate personal cloud's Public folder is mapped on PC as drive W:.
Drive X has a folder called "other" at its root which is a symbolic link to another folder on drive X i.e. "other" is a symbolic link to X:\1\2\3\other.
Drive X has many other folders at root.
When I FFS X:\ to W:\, all other folders are synced OK but while copying the "other" folder, get
Can Not Copy Symbolic Link
"X:\Other" to
"W:\Other"
I am running FFS as Administartor and on the windows PC I have run
fsutil behavior set SymlinkEvaluation L2L:1 R2R:1 L2R:1 R2L:1
Any help would be appriciated.
It seems you are using the "Direct" method for Symbolic Link handling (see Help-file).
If all else fails, you might try to create the Symbolic Link W:\Other yourself (once),
pointing to W:\1\2\3\other, and use
* the Exclude method for Symbolic Link handling if \1\2\3\other is included in the sync.
* the Follow method for Symbolic Link handling if \1\2\3\other is not included in the sync.
The symlink on X is detected and read just fine. But for some reason creating the symlink on W is not working. Maybe ERROR_NOT_A_REPARSE_POINT (4390) in this case is returned because the cloud storage does not support symlinks.
kadsf
I tried manually creating above mentioned symlink using mklink in a command windows and got the error message "The file or directory is not a reparse point."
Does this mean cloud storgae does not support symbolic links?
Does this mean cloud storgae does not support symbolic links?kadsf
Exactly. It's unfortunate however that the Windows API returns such a misleading error code. Something like "operation not supported" would have been more clear.
