When I try to run the .exe file, I get an error which basically says:
Exception: Installer cannot load the required file. Its the setup.key file being referred to.
I have malwarebytes but its been shut off so I'm not getting any notices from it when I download the file. Also no other information other than the Windows 10 Setup Exception as above.
Can't Install Donation Edition
Maybe you didn't extract the .key file from the archive?
