How do I install FreeFileSync on a Mac?
Bazsl
Where can I find instructions for installing FFS on a Mac? I am a Windows user trying to help a friend who uses a Mac. Thanks.
iLikeFree
You don't install it the way you normally install a program on a Mac.
Download FreeFileSync and you will get two program files and two text files.
Make a new folder in the Applications Folder. Call it FreeFileSync or you can call it whatever you want.
Drag and move the four files into the new folder.
Use the Green FreeFileSync Icon. The Red RealTimeSync will not work unless you upgrade.
When an update is available at a later date, delete the four files in the folder and move the new ones in. You will not lose any previous sync information.
