I have a number of folders containing the same filenames but have different contents.
If i set the compare setting to file contents it detects the 2 files are different.
However, how can I then synchronize the folders maintaining both files.
Am I missing something very obvious?
Same filename sync
FFS (FreeFileSync) retains the folder structure during syncs.
So, if the identically named files with different content are in different (sub)folders in the folder-tree in the left and right base locations, there should not be a problem.
Unfortunately for me its the same folder structure on both sides. Ideally i'd like to sync both sides and if there is a duplicate name just append the name so there is 2 copies.
Any thoughts on a simple work around?
Sorry, can't help you here!
Your description (for me) neither clarifies your situation nor what you aim to achieve.
