I accidentally entered the wrong order in mirroring. This means I mirrored a folder that didn't have my work files from the last months into the new file. So now I have two files that lack my work of the last months. It's two Toshiba external hard drives. Is there any way to reverse this?
Thank you for your help!
Kind regards
Wrong sync how to reverse
I found a way to reverse it and will from now on use "Versionierung"
