Skip syncing a file which is changing
yoshy64
I would like to skip a file which is changing while syncing. Because the file have to be synced again because it was changed during the sync, and the file is too big to sync again.
martin13pc
Did you try disabling "copy locked files" in global settings? And if that doesn't work, have you tried increasing the relevant RealTimeSync job's "idle time"? (Idle time is the delay between the time RealTimeSync notices a change in a monitored folder and the time it launches the associated FreeFileSync batch job.)
"sync.ffs_lock" files are automatically ignored by RealtimeSync. A more detailed logging is planned for RealtimeSync to make it more easy to get an overview.
