I have just installed FFS and set up my sync requirements and done the 1st sync. Does FFS now run in the background (if I close it) comparing & updating every x seconds or must I leave it running in the task bar while I want it to sync. automatically.
If not what is it I need to do to make it run in the backround (whenever I start my computer) .
thanks
Brian
Does FFS run in the background
